Coolermaster iGreen Power 430w
Appearance
Coolermaster have ‘pushed out the boat’ in the styling department of the iGreen PSU. Electroplated in a gun-metal type finish, the iGreen looks simply stunning and also very much like a unit I reviewed a short while ago from Thermaltake. The best thing about electroplating is that the finish is flawless and much better than any paint finish as you can see below.
iGreen 430w Front iGreen 430w Top
iGreen 430w Bottom iGreen 430w Finish
The highly reflective surface of the unit proved very hard to photograph without including me or an item of my household furnishings in the picture!
The front of the unit has the usual honeycomb grill as seen with almost all power supplies that utilise a 120mm fan for cooling. Also present on the front of the unit is a red LED which indicates when an Over-Volt, Under-Volt, Short Circuit, Over-Heat, Over-Load or Over-Current problem has occurred.
You may also notice the lack of an input voltage selection switch. This is because the iGreen series of PSU is able to detect the input voltage (110/240v) and switch accordingly.
iGreen 430w SideiGreen 430w Back
The sides and back of the unit are pretty standard with no ventilation holes, which will actually help keep the temperatures inside your case down, as the only exit for hot air is out the back of your pc case.
I was slightly disappointed with the use of cable ties to keep the cables in place which has a negative impact on the unit’s looks. It would be nice to see Coolermaster revising this and using a plastic o-ring to secure the cables instead.
