FSP Epsilon 700w ATX PSU
Specification
The following information has been taken directly from FSP’s website:
– Supports the latest Intel ATX 2.0 standard. Improve the System Compatibility
– NVIDIA SLI Certified
– Dual Channel PCI-Express
– Supports the latest AMD 64 CPU
– Conforms to WEEE & RoHS Environmental Directives in Europe
– Extremely low noise design, providing consumers with a quiet, good operating environment
– Ultra high power of 700W, providing the super player enough power to ensure a stable system
– Over voltage protection, over current protection, and short circuit protection can protect each part of the computer.
– High quality blue cover coating
– 12 cm light blue fan, enhancing heat dissipation and reaching the minimum noise requirement
– Neat and tight mesh sleeving improves the ventilation.
– Smart Housing easy plugable D-type connector design.
– Honeycombed cooling vents on the case reduce noise and improve the heat dissipation and air flow.
– AC Full Range Input is applicable throughout the world.
– High efficiency and power saving design >85%
– Independent 4 Channel 12V Input design. Provides stable power.
– 0.99 Active PFC. Improves the rate of power utilization.
– 20+4Pin Connector designing compatible to all motherboards in the market.
– 4+4Pin Connector design, complying with the requirement of CPU for ATX or EPS system
– S-ATA Connector design which supplies high transfer S-ATA interface products with stable power
– 2 Channel PCI-E Connector with nVIDIA dual graphic card support
– 8 Pin 12V which supports double CPUs and supplies stable voltage.
– MTBF:100,000 hours
Specs
Certainly an extensive list of features provided by the FSP power supply with some impressive efficiency and power output figures too. I’m not quite sure what a “Super Player” is though!
