FSP Epsilon 700w ATX PSU
Connectors
With 700w on tap, you certainly don’t want to be short changed when it comes to the number of devices that you can hook up. Most power supplies nowdays offer 2x PCI-E, 6x Molex and 2x SATA as a minimum, but will the Epsilon have more to offer?
All connectors are finished in black, with the molex connectors adopting the ‘easy grip’ design, which should make removal of the connectors from devices easier.
This is also true for the 8-Pin EPS12v connector which can be split in half, providing the user with a 4-Pin P4-12v connector.
