Kingdom Hearts 3 PC Port Report and Performance Review
CPU Performance – Is your CPU up to snuff?
How much CPU performance do you need for Kingdom Hearts 3? The quick answer to that question is simple, not much. While our RTX 3070 graphics card is primarily CPU-limited when playing Kingdom Hearts 3 at 1080p, adding more cores into the mix does nothing to increase framerates further. Single-threaded performance is king, and Kingdom Hearts fans will be able to get away with a strong quad-core to achieve solid 60 FPS framerates.
