Kingdom Hearts 3 PC Port Report and Performance Review
Kingdom Hearts arrives on PC – Is it the best version of the game?
Thanks to a partnership between Square Enix and the Epic Games Store, the Kingdom Hearts series has finally arrived on PC, giving more gamers access to the classic JRPG series that blends together Final Fantasy-style gameplay with Disney’s IP.
Today we will be looking at Kingdom Hearts 3, the latest numbered entry in the series, which launched originally on Xbox One and PlayStation 4 in early 2019. Being an Unreal Engine 4 title, the game was a prime candidate for a full-on PC conversion, allowing the game to surpass the limits of the game’s original console versions with more powerful PC hardware.
The PS4 and Xbox One version of Kingdom Hearts 3 run with an unlocked framerate, allowing the game to operate anywhere between 30 FPS and 60 FPS depending on the hardware demands of each area of the game. This gives the game an unstable framerate, though a lacked 30 FPS mode is also available for those who wish to use it.
On PC, Kingdom Hearts 3 has the potential to run at a locked 60 FPS framerate or run at higher framerates with strong enough hardware. The game could also run at higher resolutions than its console counterpart, allowing the game to deliver better visuals than its console counterparts.
Kingdom Hearts 3’s PC version the potential to be the best way to play the game, surpassing the game’s console release’s limitations to deliver gamers a sharper, smoother gameplay experience. That’s what this Port Report is all about.
As part of this analysis, we will be looking at the PC version of Kingdom Hearts 3, looking at how the game runs on various CPU/GPU configurations and what settings PC gamers should tweak to increase their framerate while inducing a minimal loss in graphical/visual quality.
– Graphics Options – How to change kingdom Hearts 3’s graphics settings
– CPU Performance – Is your CPU good enough for Kingdom Hearts 3?
– Graphical Preset Scaling – Getting higher framerates in Kingdom Hearts 3
– Optimisation Tip – Don’t Max out this setting!
– 1080p Performance – How achievable is 60 FPS
– 1440p Performance
– 4K Performance – Surprisingly achievable
– Conclusion – What you need to know about Kingdom Hearts 3’s PC version
Testing Methodology – Our New Test System
With Kingdom Heart’s 3’s PC version, we will be using our new Games and Graphics Card test system, which is powered by AMD’s Ryzen 9 3950X processor and PCIe 4.0 storage.
More information about this system is available here, where we have detailed why we have moved to Ryzen for our GPU and games testing.
CPU & Motherboard – AMD Ryzen 9 3950X and ASUS ROG Crosshair VII Formula
There is a lot to consider when building a new games testing system. Will this system stand up to the test of time. Does this system contain the features that new games will require, and are we choosing the right CPU platform for the job?
With the next-generation of consoles coming with Zen 2 processors and support for PCIe 4.0 storage, it was logical to choose a Ryzen-based test platform. Intel’s current offerings do not offer PCIe 4.0 support, and we cannot build a new test system knowing that it will be outdated as soon as games start to utilise faster storage mediums.
With ASUS’ ROG X570 Crosshair VII Formula, we know that we have a motherboard that has capable VRMs to withstand the punishments that a hardware test system must face. With X570, we also know that we can upgrade to Zen 3/Ryzen 4000 should we ever need to.
Memory – Corsair Dominator Platinum RGB Series DDR4 @ 3600MHz
Having chosen a Ryzen processor for our new test systems, we needed capable memory modules which offered clock speed that would allow us to get the most out of our Ryzen processor.
3600MHz memory is the “sweet-spot” for Ryzen 3000 series processors, offering high levels of memory bandwidth while settings AMD’s Infinity Fabric speeds to optimal levels. With this speed in mind, we decided to opt for Corsair’s Dominator Platinum RGB series of DDR4 modules, as it offers us a great aesthetic, has modules that offer our optimal memory speeds and has relatively tight timings given its clock speeds.
SSD Storage – Corsair MP600 2TB PCIe 4.0 M.2 NVMe SSD
As we mentioned previously, future games are going to require fast NVMe storage. Both the PlayStation 5 and Xbox Series X will make fast SSD storage a baseline feature of new gaming systems.
PCIe 4.0 devices are an obvious choice for those who want SSDs with the most potential throughput, making Corsair’s MP600 SSD a great option for us. With 2TB of storage available to it, it offers us more than enough storage for even the largest of PC games. Call of Duty: Modern Warfare/Warzone will need a lot more 50GB upgrades before we would even dream of filling this SSD.
Case – Corsair Obsidian 500D RGB SE
When it comes to PC cases we require two things, a large case (to accommodate large GPUs) that’s easy to access and looks good on camera. When new graphics cards start to flood in, we need a case that can look good on video. Beyond that, when testing new graphics cards, we need an enclosure with a side panel that’s easy to take on and off, speeding up our testing procedures.
With these requirements in mind, Corsair’s Obsidian 500D RGB SE was a perfect fit. It is large enough to accommodate any graphics card without interfering with a front-mounted AIO liquid cooler, and it has a hinged side panel to make component switching fast and straightforward. For our use case, this chassis is perfect.
Power Supply – Corsair RM1000i
Your power supply is the most important part of any test system. There’s a reason why rule number 1 for PC building is no never cheap out on your power supply.
Over the years, we have used many test systems which have been powered by Corsair’s RMi series of power supplies, and the reasons behind that are simple. They are 80 Gold rated, making them very power efficient, and we have never had an RMi power supply fail on us. If you read our PSU reviews, you will know that these units are solid performers.
Corsair Link is also a useful component of Corsair RMi series power supplies, as they allow us to see how much power the unit is using at any given time digitally.
We have also paired this unit with Corsair’s premium braided cables, which gives our test system a more premium look.
Cooling – Corsair iCUE H150i RGB Pro XT
While we are keeping our Ryzen 9 3950X at stock clock speeds, we do want to do what we can to keep it cool under load. We also want to do what we can to keep our system as quiet as possible. With this in mind, we have decided to use Corsair’s latest 360mm H150i series All-in-One Liquid Cooler.
With the iCUE H150i, we can control the units fans, pump and RGB lighting with the same software as our other system components and keep AMD’s Ryzen 9 3950X cool with relative ease. When testing graphics cards, keeping other fan noise to a minimum is a must, as this allows us to properly judge the noise levels of specific graphics cards or other system components.
Full System Specifications
OC3D Game/GPU Test Rig
AMD Ryzen 9 3950X Processor with Prescision Boost Overdrive
ASUS ROG Crosshair VIII Formula (X570) Motherboard
Corsair Dominator Platinum RGB Series DDR4 3600MHz (2x8GB) Memory
Corsair RM1000i Power Supply
Corsair iCUE H150i RGB Pro XT All-in-One Liquid CPU Cooler
Corsair MP600 2TB PCIe 4.0 SSD
Corsiar Obsidian 500D RGB SE Case
Windows 10 x64 “May 2020” Update
