Shadow of the Tomb Raider PC Performance Review
VRAM Usage
VRAM usage testing is an inherently tricky business, and VRM utilisation can depend as much on the graphics card used as the game your a playing. In most cases, VRAM use is higher than it needs to be, with games caching textures and other info within VRAM for use later, sometimes long after they have last been used.
Below is the peak VRAM usage of Shadow of the Tomb Raider under the title’s Low, Medium, High and Highest presets, though it is worth noting that VRAM utilisation increases to 6267MB at 1080p using Shadow of the Tomb Raider’s Highest preset when using a GTX 1080 Founders Edition. This represents an increase of over 900MB, showcasing how much VRAM utilisation can vary between GPUs of different frame buffer sizes.
Below is a graph to show how VRAM utilisation scales with resolution, revealing that Shadow of the Tomb Raider can use most of our GTX 1080’s 8GB frame buffer at 4K.
