Samsung 970 EVO 2TB M.2 NVMe Review
Anvil IOPS
IOPS tends to be the number than manufacturers place more emphasis on, whilst the end users just like a big MB/s transfer rate. After all, unless you’re running a multi-user server you wont be pushing the IOPS to its limit and if you are then you’ll understand the need to use a RAID solution. However, Samsung continues their fine tradition of supplying storage that can handle an enormous number of IOPS, and the 970 Evo is no exception.
