ASUS ROG NUC 970 Review
Warhammer 40K: Space Marine 2
ROG NUC 970 VS Space Marine 2
Warhammer 40,000: Space Marine 2 is one of our gaming highlights of 2024. The game harkens back to an older era, where a strong gameplay loop is king, and a single-player game doesn’t need an Oscar-worthy storyline to be good. Space Marine 2 is also one of 2024’s most demanding PC releases. At high settings, the ROG NUC can’t deliver a stable 60+ FPS at 1080p consistently in our test area. However, it should be noted that we test one of the most demanding areas of the game. If you can achieve a solid 60 FPS here, you can do it anywhere.
With DLSS Super Resolution and Frame Generation enabled, Space Marine 2 runs much faster on a PC. If you have a VRR-compatible screen, it even gives a great 4K gaming experience.
