BitFenix Shogun Review
Up Close: Interior Rear
As is the norm these days, the rear of a PC case interior is becoming quite a buy area. As you can see there are plenty of large cable tie points, with BitFenix also fitting three hook and loop fastenings in the main cable run area.
The Shogun has a very impressive 25mm of cable management room, which will enable you to do the bang up cable management job the windowed side panel demands.
If you do end up taking out all the main HDD racks, then you’ll be pleased to know that there’s a set of two stealth 2.5 SSD mounts back here.
