Cooler Master NCORE 100 Max ITX PC Case Review
Up close
Inside the NCORE 100 Max
As you can see, we are reviewing the Limited Edition Bronze version of Cooler Master’s NCORE 100 Max. Aside from the case’s standard grey version, there are no other colour options for this PC case. That said, if you are into PC modding you can easily paint your case or get this case’s aluminium plates powder coated whatever colour you want. Personally, I would love to see this case in white or candy red.
As mentioned before, this case features a skyscraper-like design. This design gives this case a small footprint and enough internal space to fit large PC components.
From both the front and the rear, this case has an elegant look. Visible cables are limited to small areas of the case, making desk cable management a relatively simple process.
Integrated power supply
The NCORE 100 Max features a built-in 850W V-series SFX Gold rated power supply. This PSU features custom-sized power cables for this PC case. This makes cable management a breeze, greatly simplifying the PC building process.
Only Mini ITX motherboards can fit inside this PC case. Within this case there is also a built-in CPU liquid cooling solution. This cooler exhausts air out the top of the case and features a custom liquid cooling radiator to ensure optimal cooling performance.
