Corsair 6500D Airflow PC Case Review
There are two ways that we can think about Corsair’s 6500 series. You can think of the series as a modernised successor to the 680X, Air 740, and Air 540, or as a Corsair alternative to case like NZXT’s H9 or Lian Li’s O11 series. Personally, I see the 6500 series as the former.
What we have here is an ultra-clean PC case design that is well suited to modern PC builds. This case supports “back-connect” motherboards, like ASUS’ BTF series or MSI Project Zero series designs, allowing PC builders to build PCs that are practically cable-free. Add on Corsair Link fans and accessories and your PC could be a cable management masterpiece with minimal effort.
Both the 6500D Airflow and 6500X versions of this case have plenty of airflow options. That said, the Airflow model does have three additional 120/140mm fan mounts. Both models looks great, but have very different aesthetics. My advice is to buy the model that you prefer the look of, unless of course you want (Crysis Nanosuit voice) MAXIMUM AIRFLOW!
With space for up to four 360mm radiators (three on the 6500X), the 6500D Airflow is a liquid cooling beast. There is plenty of space is this case’s second chamber for some hidden pumps and a reservoir, allowing users of this case to truly realise the potential of Corsair’s 6500 series design. This case was made with liquid cooling in mind, though its high airflow design is very well suited to air-cooled PCs aswell.
With an asking price of £179.99 and no included fans, the 6500X/6500D Airflow are expensive cases. That said, these cases are something that we expect owners to use long-terms. Back-connect support options an interesting upgrade path for users, and Corsair’s planned accessories for this case open the door for hassle-free customisation.
Modding options for the 6500X and 6500D Airflow
Corsair plans to releases a series of 6500 series “Elite panel kits” that will allow owners of this case to customise their systems. Anodised metal, brushed metal, and wooden panel kits are planned. These will allow users to change the look of their case with ease. The removable nature of these panels will also allow modders to customise their panels with paint or a new powder coat with minimal hassle. If Corsair’s customisation promised bear fruit, the 6500 series will be ideal for PC builders who want to build something custom.
With the 6500X and 6500D Airflow, we have a strong alternative to the other dual-chambered PC cases on the market. That said, the main differentiators between these cases and their peers are the customisation options that aren’t available yet. Corsair’s 6500 series has our seal of approval, but if they live up to their marketing with their panelling upgrades and accessories, the 6500 series will be transformed into an innovative enthusiast chassis.
You can join the discussion on Corsair’s 6500D Airflow case on the OC3D Forums.
