Corsair H115i PRO RGB and H150i PRO RGB Review
Packaging and contents
If you didn’t already know this incarnation of the H115i and H150i are RGB enabled, the colourful box helps nudge you in the right direction
The contents are well protected by polythene wrap, and the now familiar egg box card insert.
Along with instructions you also get a warranty booklet and other associated documents.
The multi language instructions are in booklet form, and although small are easy to follow.
There are fixing kits for all modern AMD and Intel coolers, including 2066 and AM4. Also included is a USB cable which goes from the cold plate to a Motherboard header, enabling the cooler to communicate with the LINK software.
The H115i comes with a pair of 140mm PWM, ML140s. and the H150i comes with three 120mm fans. All good fans in their own right, but not RGB, which we think is a rather odd choice.
