Fractal Design Meshify C Review
The Build
Along with the usual screws and cable ties, Fractal have included a rather nice lens cloth to keep that stunning Tempered Glass window free of your sticky paw prints.
The instructions are multi language, but are mainly image based, and assume the user has a degree of ability in the first place.
With everything in we can see that the internal space is very well utilised with what appears to be a decent amount of room at the front for cooling solutions.
Although not grommeted, there are a few cable management holes along the lower edge of the motherboard, which are perfect for bringing up the likes of front I/O, USB and Audio cables.
Up in the roof area, the handy management holes are in fact grommeted, which is something that isn’t seen very often, and, if you’re going to put a rad or fans up here won’t be seen here either.
The rear of the case is an easy place to work, with that main deep channel providing plenty of room for most of the cables.
Even with a 170mm long PSU, there’s still plenty of room to form the cables round before the HDD rack gets in the way.
