Fractal Define Nano S ITX Case Review
Swedish designers and case manufacturers Fractal Design have been around for quite a while now, and it’s fair to say they’ve established something of a decent reputation in the enthusiast sector of the market. Their designs are predominantly well thought out, minimalist, high quality and well priced. Enter then, the latest addition to the Define range, the Nano S. Measuring 230x203x400mm (HxWxD) the Nano S resembles a shrunken version of the Define S, which, to be honest, is no bad thing. Fractal however claim it to be ” A new way to look at the ITX form factor”, guess we’d better see if it’s worthy of that claim.
Technical Specification
| Dimensions | 230x203x400mm (HxWxD) |
| Form Factor | M-ITX |
| Material | Steel |
| Expansion Slots | 2 |
| 2.5″ | 2 (2 shared) |
| 3.5″ | 2 |
| Air Cooling |
Front: 1x140mm (2×120/140mm optional) Roof: 2×120/140mm optional Rear: 1x140mm Floor: 1x120mm optional |
| Water Cooling |
Front: Up to 280mm Max 147×312 (WxL) Roof: Up to 280mm (requires 35mm clearance on Motherboard) Floor: 1x120mm Max 85×160 (WxL) |
| Max PSU length | 160mm |
| Max CPU Cooler Heigh | 160mm |
| Max GPU Length | 315mm |
| Weight | 4.6kg |
| Front I/O | 2xUSB 3.0, Audio in/out, Power button, reset button. |
