Lian Li PC343 ATX Case
Lian Li is a name well known amongst the modding community and for good reason too. The have built up a reputation world wide for quality well engineered and designed aluminium PC cases. Their designs are sleek and subtle, never bold or brash like some other mainstream manufacturers.
Information on the PC343 is limited on-line but here are the details Aqua-PC’s advertise with the case:
⢠Construction Material â Aluminum
⢠Weight â 8,15 kg
⢠Drive Bays – 18 x 5.25â
⢠Cooling – 2 x 80 mm, 3 x 120mm Exhausts
⢠Front Mounted Ports – 2 x USB, 1 x Firewire, 2 x Audio
⢠Motherboard – Up to full size ATX
This slots in to 3 drive bays and allows you to fit 3 HDD but also has a 120mm fan to help keep those Raptors cool.
Also takes up 3 drive bays and allows installation of a front 120mm cooling fan. Aqua strangely sent us a silver module for the black case we have, but Iâm guessing seeing as they have the exclusive in the UK for this that might be the reason why!
This is a replacement panel for the roof cut out and allows you to fit a 240mm rad like the Black Ice II.
Quite simply a shroud and filter for the psu, but stops the psu drawing in warm case air. The shroud seals the PSU fan off to draw cold air in through the perforations in the floor.
There are 3 120mm fan mounts on the back of the 343 so if you donât want to use them all you will need one of these.
PC-343 Dual 80mm Fan blind £3.95 + VAT
Above the usual 120mm exhaust fan is 2 80mm fan mounts again if you donât want to use these then this is a tidy way to hide them.
This is a brilliant and cheap way to mount radiators in the drive bays.
Another replacement panel for the roof but this time an acrylic window to show off your hardware.
PC-343 Windowed Side Panel £30.00 + VAT
A replacement side panel with an acrylic window, an easy way to show off all that prized hardware.
PC-343 Dual PSU plate £9.00 + VAT
Simply remove 6 bolts and slot this plate in to add another PSU in to your system.
PC-343 Perforated Bezel £5.00 + VAT
Perfect for that extra bit of air flow, matches the 120mm Fan mount and HDD mount if you like a matching look to your case.
PC-343 Optical Bezel £7.95 + VAT
Nice and clean looking optical bay cover to match the case.
PC-343 Fan Top £11.50 + VAT
Another Replacement roof panel for 2x 120mm fans if you need that extra bit of airflow for that overclocked quad or multi GPU set up.
