NZXT H9 Flow RGB+ PC Case Review
Conclusion – We loved the NZXT H6, and we adore its big brother
The concept behind NZXT’s H9 Flow is simple. Let’s make a bigger version of the H6! We loved the H6 so much that it is currently the home of one of OC3D’s workstations. That’s high praise. A lot of PC cases come in and out of OC3D, and it takes something special to become a daily driver.
All of the love we have for the H6 transfers to the H9. It had the same design language and aesthetic. The only difference is that the H9 Flow is BIGGER! This beast of a case can have three 140mm fans at its front/side and base as intake fans. Users can then install a 420mm liquid cooler at the top for excellent CPU cooling. That’s a lot of airflow, and I think the thermal results that this case has achieved speak for themselves.
With a baseline price of $169.99, the H9 Flow is reasonably priced for a case of this size/scale. This case’s higher-end RGB and RGB+ models also represent good value when considering the cost of NZXT’s F420 RGB Core fan sets. These are great add-ons for this case, adding to the clean overall aesthetic of the chassis.
Thanks to its sheer size, this case is ready for large motherboards, cooling solutions, and graphics cards. It also has more than enough room behind its motherboard tray to make cable management a breeze. Add on back-connect motherboard support, and users have no choice but to build a tidy-looking system inside this enclosure.
NZXT has harmed this case’s launch with its poor timing
If I am honest, this launch has me a little baffled. NZXT is revealing this case at Computex and is having reviews go live at the same time. Since most big tech analysts and reviewers will be travelling to Computex, these plans have given us precious little time to review this case. It also guarantees that everything else at Computex will overshadow our review coverage. If we didn’t know any better, we’d say that NZXT was trying to bury this launch, just like how Nvidia’s trying to bury their RTX 5060 8GB launch.
The problem is that NZXT isn’t trying to hide this case. It’s big, it’s beautiful, and it deserves its time in the spotlight. Yes, reveal your case at Computex, but release the case and let reviews go live a few weeks after the event. If you did that, reviewers would have more time to work with the case. Furthermore, it would give your case more time in the spotlight. This isn’t an Nvidia situation. You had no reason to bury this case’s reviews with Computex coverage. NZXT, you have done the H9 Flow a disservice.
Closing Thoughts
There isn’t much more to say here. We love the H9 Flow. If we had more time with the case, we would probably have moved Tom Logan’s (OC3D’s big boss man’s) main rig into it. Like the H6 Flow before it, the H9 Flow is a cracking case.
With its three 140mm bottom intakes, this case’s GPU cooling potential is simply fantastic. It is ready for the biggest and hottest components. With its panoramic glass and angled front/side intakes, this case has more personality than its cube-like peers. Furthermore, this case’s clean aesthetic is unmatched when used with NZXT’s F420 RGB Core fan sets. NZXT has created a thing of beauty here.
You can join the discussion on NZXT’s H9 Flow PC Case on the OC3D Forums.
