Phononic Hex 2.0 Peltier CPU Heatsink Review
Packaging and Contents
The Hex 2.0 comes packaged in a high gloss rigid card box, the exterior of which shows minimalist graphics and key features. Â One things for usre, Phononic certainly like their Green.
Â
The lid lifts off smoothly to reveal the cooler secured within. Â also inside are a box containing accessories and cables along with an instruction booklet.
Â
To release the cooler which looks more restrained in a Hannibal Lecter kind of way, than actually supported, you first have to lift it out of the box before cutting the cellophane
Â
The instruction book is extensive although the diagrams are a tad on the small side. Â We also noted that a few pages had been added in loose after printing suggesting that this may be a very early production model. Â We’d imagine that once things are underway, the pages will be inserted properly at the printers as opposed to added later.
Â
The accessory box contains a universal backplate, mounting hardware for AMD and Intel (including 2011 v3), a Noctua style screw driver, a good sized syringe of TIM, a fan extension cable, and a mini USB cable.
