Phononic Hex 2.0 Peltier CPU Heatsink Review
As Monty Python once said, “And now for something completely different”. Why so? Well the Hex 2.0 from North Carolina Based Phononic is a cooler of the type we’ve never tested before. Although it might look like a standard CPU tower cooler, it is in fact so much more than that. In simple terms it’s a device which utilises the Peltier effect to cause a heat flux between the union of two differing materials. The effect creates a temperature difference by transferring heat between two electrical junctions. When a current is applied between the two conductors, heat is removed at one junctions and thus cooling occurs. The device is often referred to as a Thermoelectric cooler (TEC), and is also known as a Thermoelectric pump or Peltier device. At just 125mm tall it’s also petite enough to fit into a good many Small Form Factor cases. So is this the answer to extreme cooling in small spaces? Best you read on and find out.
Technical Specification
| Dimensions | 125x112x95mm (HxWxD) |
| Weight | 810g |
| Intel | 2011 (incl v3) 115x |
| AMD | AM2/+, AM3/+ |
| Fan | 92mm |
| Fan Speed | 2650rpm |
| Airflow | 44CFM |
| Static Pressure | 3.1mmH2O |
| Noise | 33dB(A) |
| Power | 6pin Aux graphics cable |
| USB | Enables Hex 2.0 dashboard |
Key Features
Small Form Factor
High Performance Integrated and Swappable 92mm Fan
Supports TDP Power for Over Clocking Beyond 140W
Low Noise Design (33 dBA @ max speed)
Active/Passive Cooling (Using Phononic’s Thermoelectric Technology)
Integrated Electronic Control Applies Active Cooling only When Needed
Optional Application Software and User Interface Allows User to Adjust Performance Characteristics
