Waterblock Shootout
It is a well known fact that water-cooling is really beginning to become a viable mainstream alternative to traditional air-cooling measures. No longer is water-cooling purely the domain of the hardcore overclockers, but ever increasingly it is beginning to make its way into more and more people’s homes.
With the advent of quad-core processors and the successful saturation of the market with dual-core processors as well, a need has arisen for cooling methods to tame these multi-cored beasts. So how do we look towards cooling these processors more efficiently…With water-cooling of course!
– Designed for Quad and Dual Core CPU’s
– High Performance Copper Base With Over 1600 Copper Pins
– Pins Precision cut to 0.4×0.4×4.2mm
– 26mm Stepped Base
– CNC Cut Acetal Top
– G1/4″ Threads
– Universal Mounting Plate
– Supports Sockets A/462, 478, 604/603, 701
754/939/940, AM2 and LGA775
Block Base Dimensions: 50mm x 50mm x 7.2mm (2.0” x 2.0” x 0.3”)
Height (including barbs):37.2mm (1.5”)
Port Threading: Standard G 1/4″
Barb Size: Chrome Plated 1/2″ & 3/8” bards provided
Net Weight: 239g
Top Material: CNC machine Delrin
Base Material: CNC machine C110 copper mirror finished
Mounting Type: 478 and 775
Flow Rating: High
Base Material: Copper
Top Material: Plated Aluminum
