AMD 3rd Generation Ryzen Threadripper TR 3960X Review
Test Setup
AMD Ryzen Threadripper TR 3960X
G.Skill Trident Z 3600 MHz
Corsair Vengeance RGB 4000 MHz
Corsair MP500 M.2 – OS Drive
Aorus PCIE4 NVME – Storage Speed Tests
Nvidia RTX 2080Ti
Corsair HX1000i
Corsair H150i
Corsair ML Fans
Windows 10 1903
Overclocking
Naturally when you have this many cores available, the need to overclock it is greatly reduced. Partly because it’s so powerful already, but partly because getting 24 cores to overclock without abusing your cooling solution or finding one core that isn’t so happy to be pushed is asking a lot. However, overclocking all 24 cores is certainly possible and we managed to extract 4.3 GHz from the TR 3960X.
It is worth noting that the new Agesa update which improved the single threaded performance, coupled to the excellence of the prioritised cores and selective turbo work brilliantly at stock and are over-ridden when you manually overclock. Thus in those few tests we have which test the single threaded performance individually will see better results at stock than overclocked.
