AMD 3rd Generation Ryzen Threadripper TR 3960X Review
HEVC
HEVC does a similar thing to the x.265 benchmark but instead of running with the x265 encoder it utilises the popular H.265 format which is rapidly becoming the standard for video encoding.
H.265 slightly prefers the Intel setups to the AMD ones. Worth taking note of if you have to do a lot of video encoding, X.265 is the way to go on AMD systems.
