ASRock Taichi X399 Review
Test Setup
MSI X399 Carbon
AMD Threadripper 1950X
Corsair LPX 2666MHz
Corsair LPX 3200MHz
Gskill Trident-Z 3200MHz
Corsair H100i V2
Noctua NHU14S TR4
Corsair MP500 M.2
nVidia GTX 980
Corsair HX1000i
Overclocking
Using the Tachi was actually VERY simple and easy. One thing we were concerned about was a buggy BIOS based on our experience using the X370 board. We are happy to report we had and found no issues what so ever! We found our CPU max quickly and easily and a huge plus point is Asrock are not using the standard AMD voltage offsets. Some brands dont give you full control of your voltages when manually overclocking and seeing such control with the Asrock is actually very refreshing with current AMD boards.
CPU Temperatures were about 8-10c warmer than we have had on other boards and we did try remounting our cooler several times to try and rectify this. We came to the conclusion that there must be a hidden section in the BIOS that needs tweaking a little and we would urge Asrock to investigate as this was our only (some what minor) gripe.
VRM Temperatures
As you can see below the additional heat sink has managed to keep the VRM temperatures down, quite a lot cooler than the single heat sink cooled MSI board.
