ASUS ROG Zenith II Extreme Review
AIDA64
Since its early days as Everest, AIDA64 has provided an excellent way to benchmark your system without requiring you to take a week off work whilst the tests run. From the memory bandwidth benchmarks which test your throughput, to the CPU benchmarks which vary in scope to test everything from raw calculation – CPU Queen – through compression algorithms – zLib – and the all important encryption – AES256.
The new memory controller on the 3rd Generation Threadripper eliminates a minor weak spot in the 2nd gen models and the Zenith II takes full advantage.
