i5 11600K vs AMD Ryzen 5 5600X with RTX3080 Gaming Review
Average FPS – 4K
And lastly the 4K. You can also see on this graph exactly why we chose the RTX 3080 as our GPU. With every setting to the maximum you’re either getting 60FPS or very nearly doing so, where a single turning down – say from 8xMSAA to 4xMSAA – will be enough to break the 60FPS barrier. The RTX 3080 is a big seller for good reason.
