Intel Core i7-13700K Review
CPU Temperatures
Our CPU temperature testing is a juxtaposition between best and worst case scenarios. We run a seriously heavyweight CPU cooler, which shows the best use case, and then torture the system for 30 minutes to get our peak reading. Otherwise known as the worst case scenario. Note that our overclock is always fine-tuning the volts in a way that a stock setup doesn’t and thus usually – but not always – ends up running cooler than stock.
