MSI Z590-A Pro Overview
Wrap Up
There is no doubt that the MSI Z590-A Pro punches above its weight when it comes to connectivity. The main difference between a B chipset motherboard and the full Z is usually found in the amount of things you can plug in, and this also applies to the comparison between products such as the Z590-A Pro and, for example, the MSI Z590 MEG Ace. However, we were pleasantly surprised with what the Z590-A Pro brings to the party, particularly when you consider that it costs the same price as the Core i5-11400 we love so much.
When the Rocket Lake was first mooted the idea of being able to get a hugely capable gaming CPU and put it into a full fat Z590 chipset equipped motherboard for under £350 seemed like madness. Hell the MEG Ace alone costs more than this i5-11400/Z590-A Pro and some decent DDR4 would cost. Yes the Ace has more features, but does it have more that you’d actually use? For a gaming platform we seriously doubt it, and although the looks might be a little divisive we’ve at least come a long way from the days when the affordable motherboards came with 7 different coloured plastics on a bright blue PCB. Once it’s stuffed full of hardware you won’t notice anyway, should you be in the “not my cup of tea” camp.
The MSI Z590-A Pro proves it’s possible to get all the benefits of the latest Intel Chipset and all it’s PCI Express 4.0 speed without scratching the bank, let alone breaking it.
Discuss the MSI Z590-A Pro in our OC3D Forums.
