MSI Z170A MPOWER Gaming Titanium Preview
Up Close
Up Close
It would have been easy to attempt to make a silver motherboard but end up with one that was battleship grey. Just like some white motherboards are yellowish or beige. But MSI have really nailed the looks of the Titanium. It, frankly, looks spectacular. The monochrome colour scheme lets you have any lighting you like, and yet if you choose to go with none then the motherboard shines brightly enough on its own.
MSI Z170A MPOWER Gaming Titanium Preview     MSI Z170A MPOWER Gaming Titanium Preview
Wherever you look on the Titanium you can see the reinforcement MSI have added to ensure that your purchase can handle the most extreme situations for as long as you use it. By covering the slots in metal it also gives a more harmonious look to the Titanium. They blend in nicely with the silver PCB to bring a neutrally coloured, but still gorgeous, motherboard to the masses.
We will cover the storage options on the next couple of pages, but if you're the type of person with an enormous collection of drives it's somewhat surprising to see how few SATA ports the Titanium is equipped with. There are no such issues on the back though as there are plenty of USB ports alongside the Intel LAN and MSI Audio Boost 3 outputs.
«Prev 1 2 3 4 Next»
27-07-2016, 13:37:48
Ekksanpher
Apologies in advance!
As the title suggest I have encountered an issue with my mpower titanium z170, I'm just trying to determine whether it is a problem with my mobo, or whether its an issue with all of them, such as an early Bios Problem. My question is:
Do all the fan headers function normally? particularly CPU1 header.
with mine, regardless of fan type, all fans spin what I would consider slow, with CPU1 header not working at all. 100% spin speed set in bios and command center.Quote
27-07-2016, 14:38:21
tinytomlogan
Download HWmonitor and see what the RPM speed is because 'slow' could mean many things, have you set everything up in the bios or have you just left it alone, are they PWM?
There are many many more questions that come out of your original one if you would like a proper answer.
Its 99.99999% a config issue though and not a fault.Quote
27-07-2016, 15:20:05
Ekksanpher
Thanks for getting back. The truth is I have many questions regarding the issue! (sorry in advance for filling the forum with stuff that should go to MSI Support!)
So as for PWM, yes, and no. I have been testing with both pwm fans and 3pin, both seem to have the same problems in all the headers, (minus CPU 1).
N.B: All components are new and installed new into the system.
With regard to config, I hope it is a config problem as well, but I think it may be a little more that just a few settings not ticked if you know what I mean, which is why I wanted to see if anyone else had the same issue with the board!
With settings, I went into BIOS and on the most recent visit set "Set All to 100%", and then checked this using MSI command center software to check CPU 1, CPU 2, sys 1, 2, &3 headers are to max which they were.
If I plug in any fan into CPU 1 it will not spin. If I plug in my AIO pump, the light on the pump flickers, but in the mostly off kind of way. I suspect CPU1 header is damaged.
CPU 2 Header works (sort of) and has full PWM support, so I will be referring to that header with these numbers, so initially, I had an AIO hooked up, but it was idling at 60'C! (6700k non overclocked) so i swapped that with an intel stock cooler, so the pump may be faulty but I suspect not.
Now for RPMs.
the stock cooler stays at ~2000rpm with settings set to 100%. Now we all know how loud they are! well this isn't loud, which is what I meant by "slow", now if I unplug and replug it into the header, it ramps up to 3000rpm for ~2secs and ramps down, and stays down. That ramp up to 3000rpm is the noisy stock cooler at its best that we've all come to love!
Now with the (maybe faulty) AIO, in the same header, it will flicker between 0 and 1800rpm (yes plugged in correctly), then settle at 0rpm once left alone (the LED is solid on in this time, no flickering LED. this is what I believe was causing the high idle temps. This gives me the feeling that the MOBO isn't delivering enough power to each of the fan headers, as it seems unable to sustain the maximum or operation speeds.
This makes me think it may be a BIOS problem, but being such a new MOBO, there isn't one to update to! And since its a new mobo, there are currently no forum thread that I have found yet to check with!
if you've read this far you are AWESOME!Quote
27-07-2016, 21:09:33
Excalabur50
What power supply are you using and also make sure the 24 pin and 8 pin power connectors are firmly on the board it only takes one to be slightly loose to give you issuesQuote
28-07-2016, 06:24:06
tinytomlogan
Now for RPMs.
MSI will be in touch with you in this thread to try and helpQuote
