MSI MAG 322URX QD-OLED Review
OSD
OSD
A good quality On-Screen Display is key to maximising the utility of your display. The MAG 322URX has all the options you might expect. Presets for each mode are a handy one-stop place to test things out.
If you want to reduce the blue light, or just ensure your productivity has accurate colours, MSI have you covered here too.
More standard image controls are available. Thankfully being an OLED display means that brightness will never be an issue.
Here is where the important stuff is found. Even if you’ve no interest in the many options above, you need to check these out. MSI give you a great warranty, but it never hurts to help yourself in the long term. If just turning on Pixel Shift and Taskbar Detection will greatly lengthen the lifespan of your investment.
