ASUS ROG Falchion Wireless Mechanical Keyboard Review
Armoury Crate
Once you get it up and running – a task which is a considerable faff if it’s your first time installing the Armoury Crate and Falchion onto your system – you’ll find all the controls and adjustable elements clearly labelled and easy to tweak to your own taste, from the simplicty of lighting setups to assigning the touch panel on the side or just keeping an eye on your battery life.
