ASUS ROG Keris Wireless Mouse Review
Mice are easily the most important connection between you and your computer. There is a reason that they are listed as Human Interface Devices, and whilst having a great keyboard is a huge benefit, the ability to have everything you need to get through your workflow at your fingertips is paramount. If you can get that attached to a sensor which lets you hit your mark every time then the difference in your efficiency – be it gaming or editing videos etc – is stark.
In recent years there has been something of a split in the mouse market. On the one side we find mice which are hefty, with buttons absolutely everywhere, and on the other side are mice which pare things down to the essentials and thus reduce weight and stop you accidentally switching profiles in the middle of a hefty firefight. We’ve all done it.
Enter the ASUS ROG Keris Wireless. A mouse which sticks to the class leading formula of an accurate sensor, Omron switches, and light weight. The Keris has another trick up its sleeve too with swappable side buttons, spare microswitches and a wireless system so instantaneous that you forget you’re not wired. It’s the mouse for those who want a pure experience.
Technical Specifications
