Coolermaster Mastermouse MM520 and MM530 Review
Up Close – MM530
If the MM520 is a mouse that is designed for the claw grip with absolutely no concessions to the palm grip players, then the MM530 is far more flexible. Firstly it is less obviously right handed, so if you’re a leftie who has had any experience of using the back and forward buttons on the left hand side of the mouse then you’ll be at home here. Secondly both sides of the MM530 are covered in lovely soft-touch textured rubber for aided grip. Lastly there is an extra button behind the RGB scrollwheel that will expand your customisation possibilities. You could even dedicate it to the Tactix shift function without compromising your on-the-fly DPI switching capabilities.
