Phobya LED-Flexlight
Phobya have been around for a little while now, producing quite a wide and varied catalogue of products, all the way from watercooling equipment to case lighting options. It’s this latter area that we concentrate on here looking at Phobyas extensive range of LED Flexlights. Thery’re available in 5 colours and UV and also offer an RGB version which has the ability via a (remote control no less) to switch at will between what ever colour or combination of colours takes your fancy. The Flexlight can be bought in 30,60,120,240 or 500cm lengths with the options for high density or low density LED spacing.
Tech Spec
| Model No. | 120cm : 144x SMD LEDs |
| Length | 120cm |
| Colour | Green, Red, Blue, White, Warm White, UV, RGB |
| Width | 10mm (in the light stripes) |
| Number of LEDs | 144 |
| Voltage | 12V – 14V DC |
| Connection | 4-pin Molex |
