Seasonic M12 600w Modular PSU
Specifications
The following information has been taken directly from Seasonic’s PDF datasheet available here.
• Specification compliance: ATX12V v2.2 & EPS12v v2.9
• Support the latest Intel Core 2 Duo / Extreme & AMD AM2
• 80PLUS Certified: over 80% efficiency
• Multiple +12v output
• Double forward converter design
• Dual Magnetic amplifiers
• Dual fan cooling
• Smart & Silent fan control
• Low ripple and noise
• Short circuit protection on all outputs
• Over voltage protection
• Over power protection
• 100% hi-pot test
• 100% burn in, high temperature cycled on/off
The observant among us may have noticed that both the 500w, 600w and 700w models all have the same rated amperage output across all of their rails. However, a closer look shows that combined amperage output (when all rails are placed under load) is quite different between the 3 units. The 500w unit offers a maximum output of 30a across all +12v rails with the 600w and 700w units offering 48a and 56a respectively.
