Seasonic M12 600w Modular PSU
Looking Inside
My favourite part of any power supply review has to be taking the unit apart and having a poke around inside. By doing this we can usually get a good idea about the quality of components used and how the unit is likely to perform in our tests.
Turn the PSU around, and we can see two wire-wound inductors sitting below one of the large ‘claw’ shaped heatsinks. Inductors perform a similar role to capacitors and assist in providing steady, clean voltage to the components in your computer system.
Model: AD0612HB-D71GL
Size: 60mm x 60mm x 15mm
CFM: 16.6cfm
dBA: 32.4dba
RPM: 4500rpm
Model: AD1212HB-A71GL
Size: 120mm x 120mm x 25mm
CFM: 85.2cfm
dBA: 39.1dba
RPM: 2200rpm
More information on ADDA fans can be found here.
