Seasonic M12 600w Modular PSU
Appearance
Seasonic have never been the kind of company to go for funky colours and flashing lights in order to shift their power supplies. As we can see below – this ‘no bling’ trend has been continued in their M12 series.
The back of the unit has the usual honeycomb grill as seen with almost all power supplies that utilise a 120mm fan. This allows for the hot air circulated by the fan to exit out the back of your PC case. You may also notice the abundance of a voltage selection switch. This is because the M12 is able to detect the input voltage (110/240v) and switch accordingly.
The front of the unit offers a fresh talking point – a 60mm fan covered with a silver fan grill. This was put in place to give airflow to the areas of the PSU that the 120mm does not reach, and also to assist in the extraction of hot air through the mesh at the back of the PSU.
