PC Specialist LS-H01 Review
Storage Speed
If you’re not used to the speeds available from a good M.2 drive that works with Intels NVMe technology then the following screenshot might just blow your mind. In short, no matter how big your file is the Samsung SM951 can transfer it, read it, write it or whatever as swiftly as you could possibly hope.
Temperatures
With two radiators and plenty of fans blowing air across them it’s not at all surprising to see that even after a lengthy Unigine Heaven loop the GPUs only hit 50°C. It’s perhaps slightly more of a shock to see the Core i7-6700K making it all the way up to 70°C, but that’s still well within the thermal limit and it’s obviously heavily overclocked.
