PC Specialist LS-H01 Review
Lighting
With the side off the LED strips can easily replicate the Close Encounters Of The Third Kind effect. They could double as a lighthouse in a pinch. With the side on the internals are lit up beautifully. It’s definitely bright, as you can see from the fan vent holes shining onto the wall. If you’ve got something this nice, show it off.
Speeds
The EVGA SuperClock version of the GTX 980 Ti comes in at 1102 MHz, with 7012MHz GDDR5. Couple these up to the 4.6GHz overclocked Core i7-6700K and there will be nothing that the LS-H01 cannot handle.
