PCSpecialist Lunar Spark Review
AIDA64
We’re comparing the Lunar Spark to the most affordable of the recent PCS systems we’ve tested, the Topaz Elite. The Topaz Elite is significantly more expensive at £1400, and that extra £400 brings you an upgrade to the GPU – RTX 3070 instead of RTX 3060. There is also the AMD Ryzen 5600X CPU, dual channel DDR4 and a NVMe M.2, so it’s a big step forwards in ability and that’s worth bearing in mind during our testing. The Lunar Spark is designed for gaming first and foremost, and the single channel DDR4 will make a dent in the memory bandwidth. But it’s under a grand, so you can’t complain.
