PCSpecialist Momentum Elite System Review
Managing to put together any system at all in the current climate without blowing past the thousand pound mark is difficult. You really have to make careful choices about your planned use, and how best to utilise your money. We have often said that PCSpecialist are the masters of extracting maximum value for money, and the Momentum Elite is no exception.
On paper one might feel that it’s seriously underpowered. A 5000 series Ryzen, and not even one of the fast ones? A chipset from the dawn of time with no USB Type-C? Just a Gen4 M.2 drive? But stop for a moment. Let’s say this is being used for coursework and some gaming. We’ve said for years that any budget, once you’ve got the basics in place, should be spent on your GPU for maximum bang for buck. The PCSpecialist Momentum Elite sticks to this ideology.
As we saw from our testing the processor, a six core 4.4GHz one don’t forget, is more than enough for nearly anything. With the speed of the Nvidia CUDA cores on the RTX 5060 you can also leverage them for blistering rendering performance. As you saw from our Cinebench R26 test. There are many video encoders that utilise the GPU. So even if you don’t plan to game, or you’re buying this for little Suzis schoolwork and don’t want them gaming, the money expended upon the graphics card is well spent.
Of course everyone games. At this budget the facts are always that you can game with all the settings on maximum at 1080, 1440 and 4K in the popular, undemanding titles. But you can have most settings at maximum in the stiff titles even at 1440, as our results show. Cyberpunk 2077 with ray-tracing on at 1080 is easy, such is the prowess of the RTX 5060.
As a pre-built system the PCSpecialist Momentum Elite comes at a bargain price. Particularly with memory prices still through the roof. If you did have some wiggle room in the budget we’d immediately get more system fans – even one would help – and a better CPU cooler. You don’t need much, but cooler temperatures mean more performance and more longevity. Important when money is tight. For the price though the Momentum Elite is surprisingly capable as a great value gaming rig and wins our OC3D Gamers Choice Award.
Discuss the PCSpecialist Momentum Elite in our OC3D Forums.
