PCSpecialist Momentum Elite System Review
Up Close
Up Close
Anyone can build a rig with unlimited funds. There’s no challenge there. As you gradually make your way into ever tighter budgets, so compromises have to be made. We would always give us aesthetics first. In the case of the Momentum Elite you get a case which is functional but just has a little bit of flash. The diagonal, 10 o’clock, line on the front lights up.
You don’t get any front panel USB Type-C though. Just three Type-A and the power/reset switches. As well as front panel audio should you still be on a 3.5mm headset.
Around the back the cost compromises also show up with the IO. We can’t recall the last time we saw a motherboard which not only had a PS/2 port, but also had a finger-slicing separate cover. Bit of a trip down memory lane for us.
Oh, if you were curious as to the lack of front panel Type-C USB, you won’t find any round the back either. Or any way to wirelessly connect your phone. As we said earlier, compromises have to be made at this price. Only you know how bothersome this particular one is. For us, where all our test games are on massive external drive and copied across to save our internet, it made for a long, slow, expensive week.
One thing that always impresses us is how PCSpecialist don’t care about the price of the rig, they’re all built to the same high standard. Foam insert to keep all your hardware safe during courier .. attention.
And once that’s out you can see that the cables are as neat as anyone could hope. It’s quite funny to see a motherboard without a top row of VRM. We’d almost forgotten how simplistic the AM4 options could be. The AMD stock cooler pretty much dominates the top half and, as this isn’t a full ATX motherboard, only the GPU really takes up the bottom.
Storage is still M.2 though. Obviously it’s not the fastest or biggest drive in the world, but M.2 drives are brutally expensive. See our memory comments at the start. Kudos to PCSpecialist for managing to still give us a 1TB Gen3 drive.
