PCSpecialist Quartz Elite R Review
Gaming – Average FPS
Obviously the most important thing to note here is we’re running at 1440P, which is a little above what the RTX 3060 is designed for, but this is to give you a worst case scenario. All the details to maximum and 1440 is the harshest test this is likely to obtain, and dropping to 1080 will give a big improvement, even if you keep the detail level the same. Or, if you happen to have a 1440 monitor, then lowering the settings a tiny bit can push you into 60FPS land on those couple of titles that struggle. Control and Godfall in particular are so near to 60 FPS you can really get a feel for how good the RTX 3060 can be, and note that Wolfenstein is run on the Uber setting. It’s also good to see how much a beefier CPU can help, with Youngblood and Godfall in particular gaining plenty of FPS on the Ryzen 5800X.
