The Gigabyte Rig Review
Temperatures
The air cooled nature of the Gigabyte setup means that there is a little more heat in the system than the ROG one, and the longer you run then the more soaks into the system which leads to the GPU and CPU temperatures being a little higher. The Aorus Pro motherboard itself remains cool regardless. This is very much a worst case scenario as we deliberately ran things to make it as hot as possible. Regular use is naturally cooler.
