Corsair HS60 Pro Surround Headset Review
Software
There might not be any lighting to tinker with in the iCUE software but you can still – if you use the USB adaptor – adjust the HS60 Pro into stereo or 7.1 surround modes. You will also find the capability to tweak your equaliser settings using either connected sliders for a smooth profile or unlinked ones if there is a particular frequency you want to boost or cut.
