Corsair HS80 RGB Wireless Review
iCUE and Dolby Atmos Software
The Corsair iCUE software is easily the best of the main ‘big’ manufacturers. It’s easy to use, controls far more of your system than it has any right to, and unlike some we could mention doesn’t fall over at random intervals. If you’ve ever glimpsed the controls available to you on a Corsair product then this will all be very familiar.
Dolby Atmos is a seperate download from the Microsoft store, but is nice and easy to use with a fairly small footprint and plenty of adjustability. If you’re going for the HS80 then you owe it to yourself to maximise it’s capabilities, particularly if you mainline one of the games that has native Dolby Atmos support.
