beQuiet Silent Loop 360mm AIO Watercooling Review
Up Close: Packaging and Contents
As is usual for a be quiet product, the Silent loop 360 comes in subtle black packaging, with a moody illustration of the cooler on the front, and tech specs and key features on the side and rear panels.
Inside it’s business as usual with egg box card surrounding the contents, each of which is individually wrapped in plastic bags.
You get fittings for a whole host of AMD and Intel CPUs. There’s also a syringe of TIM, a 3-way fan adaptor and a full set of short and long screws for mounting fans.
The instructions, although extensive aren’t particularly clear, which if you remember has caused us problems in the past. It’s all in there, you’ve just got to find it.
