Cooler Master Booth Tour at CES 2024
Accessories
Meet the Cooler Master MasterHub
Cooler Master’s MasterHub system aims to accelerate your PC workflow with a suite of customisable hotkeys, dials, knobs, and other controllers. Unlike relatively static solutions like Elgato’s Steam Deck, the MasterHub can be changed and modified to suit your needs.
The MasterHub is a base board that has various connectable elements. These elements can be moved or replaced with ease, and multiple MasterHubs can be used together to create more complex control setups. This versatile control center gives Cooler Master the option to release more control options in the future, and allows users to replace or upgrade areas of their MasterHub setup when required.
Vertical GPU Holder with ARGB lighting
Next up we have a new Vertical GPU mounting kit from Cooler Master. This new kit is designed for both ATX and MATX systems and features a PCIe quick release system to make PC building and upgrading and easier process. The mount also features a rotatable RGB lighting element, allowing users to customise their vertical GPU setup with some RGB flair. This vertical GPU holder can be adjusted up to 65mm towards a case’s front panel and 30mm towards a side panel to support a huge number of PC cases.
