CoolerMaster MasterCase Pro 6 Review
Up Close: Interior Rear
As you might imagine, the rear of motherboard area of the Pro 6 is also the same as the 5 series cases. Not that that’s a bad thing, there’s a lot going on back here. Ample management space and plenty of tie points and velcro tapes along a cable channel. Care should be given if you think that what looks like a handle at the rear is load bearing. We went to pick the case up by this and it damn well nearly snapped off in our hands. In reality we think it’s actually just a support for the top cover. Good job we were concentrating.
The PSU has to be slid in from the rear after first removing the outer mounting plate. It then sits on these two full length foam topped rails.
Mmmmm Cable management goodness right here.
If you’re going to take the drive bays out from the front side, you might want to keep these in. Alternatively they can also be removed to fit in larger Rads.
