Fractal Design Meshify S2 Review
Accessories and Instructions
The S2 comes with a compact accessories box which is held captive in the lower most of the three rear of motherboard 3.25/2.56″ drive cages.
As you can see, it comes with pretty much any screw you could ever want, to see you through this build and we dare say have a good many left over. you also get a set of cable ties, a SATA power take of for the PWM fan controller, or anything else you care to use it for, and a brace of flexible reservoir mounting brackets. The cream on the cake though is the rather nice black glass wipe cloth, and if you don’t use it for that, it’ll shine your glasses up a treat.
The instructions are mainly image based and although clear, and very “Fractal”, could do with going into a little bit more depth. For example, the image below details the rads that can be used, but does not detail which thicknesses are compatible. We guess that’s where we come in.
