Lian Li TYR PC-X2000 Chassis
Interior Impressions
Let’s start at the front and work our way around the case. Underneath the front panel are three 140mm fans and the fan controller. Access under the panel is easily achieved by pulling the panel away from the chassis. It’s worth noting that it does come away quite easily, and those with young children may want to take note of this. To gain access to the fan controller, which is a simple three way switch, you need to remove the front panel and then slide out the massive dust cover. The dust cover is a plastic frame with nylon mesh acting as the filter. I do think Lian Li could have chosen better placement for the controller and made it more easily accessible as you will have to remove both the front panel and the dust cover to gain access.
Moving onto the sides, the side panels are made of one single piece of Aluminium, and they have are fixed in place using a sliding locking mechanism, which is fastened using a single thumbscrew. The panels have foam stuck on the interior face, and this is intended to aid noise dampening.
From the left interior view we can see the compartmentalised design of the X2000. There are three main compartments, with separate areas for the PSU & optical drives, motherboard & add-on cards, and then the hard drives.
Then if we move around to the right side of the case, we can see the removable motherboard tray, and once again the optical/ floppy drive bays. The motherboard tray is secured by three screws along the top of the tray and two thumb screws on the rear outer face. Removal is painless and simple, and is a welcome addition.
