Lian Li TYR PC-X2000 Chassis
Internal Impressions – A closer look
SATA Hard Drive Hot Swap Bays
The X2000 features six hard drive bays, with two three bay hot swap boards. The boards take care of your drives SATA and power connections, and you connect the cables from the motherboard and PSU to the rear of the boards. A welcome bonus to this setup is the fact that you can power three drives from just the one molex connector on the board. Access to the rear of the boards is gained from the right hand side of the case, when the side panel is removed. Fixing the drives in the bay is achieved by attaching the supplied handles to the drive and then slotting it into an empty bay – all you then do to lock it is push down two clips. This system works brilliantly. Not only does it allow you to swap out hard drives quickly and painlessly, it provides an easy way to keep drive cables in check.
Cooling
The X2000 comes equipped with three 140mm fans to the front, and one 140mm to the rear. In addition to this, there are two 80mm fans at the rear. The three front fans act as air intake’s, and blow air into the main chamber and the hard drive compartment. The 140mm fan at the rear is positioned in line with the CPU and acts as an exhaust for the hot air. The two 80mm fans are positioned in line with the drive bay and exhaust hot air from there. All fans are fitted with grilles and this gives the case a finished feel. In addition to the fitted fans, the PSU bay has a slotted floor, which will allow hot air created in the main chamber to be exhausted through the PSU fans. We will discuss how effective this cooling setup is in our testing results page.
